This is the Select a Color digital clock. There are buttons on the back of the clock, but pressing them does nothing,
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
SOURCE: Setting the Time
First, turn the Function Knob (bottom-left of the Control Panel) to “Clock”.
Hours: Press and hold the “HR” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press(pulse) the button to advance one digit at a time.
Note: When the number passes 12, the PM light will be displayed on the LCD.
Minutes: Press and hold the “MIN” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press (pulse) the button to advance one digit at a time.
To finish setting time, turn the Function to any setting other than "Clock", or simply wait until the numbers stop blinking.
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
SOURCE: alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Good Luck and please rate 4 thumbs up for the free answer.
