Machine is 4 yrs old with normal usage times
SOURCE: F 21 error code
"F21" is a long drain error code. This is most commonly caused by something obstructing the drain pump, or drain lines. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
I would begin by checking the drain pump reservoir for small debris. You would be amazed as to what finds its way into these pumps. The link I provided also gives instructions on how to check the drain pump.
If you clear the drain pump and the problem still presists, verify all the drain lines are clear. If all these preliminary checks still result in an error code, more than likely the drain pump is damaged and requires replacement.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
SOURCE: I HaVE A WM63 HOTPOINT WASHING MACHINE, IT FILLS
I'm afraid it is a faulty timer control board problem, the only solution is to replace the control unit, an expensive repair, at 10 years old, I personally think you would be better off replacing the washer.
Testimonial: "thank you so much saves me 25 pounds to call the man out thats before he starts the problem. very helpfull thanks ."
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
SOURCE: I have a Bosch dishwasher
Mine does the same thing. Did you ever get yours working again? If so, what was the problem?
