Remove share option In tab view in browser and remove the request desktop also . I need to set it on mobile view
SOURCE: Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
SOURCE: Kenmore 20 porcelain plus refrigerator
5' 6" Tall
32 1/2" Wide
28" Deep
I bought that old fridge at a garage sale for cheap. It's been enjoyed for me for just over a year. :)
SOURCE: Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Hope this helps everyone else as it did me, thanks
SOURCE: How do I remove the guide plus from coming on at power up?
I found the solution!
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
SOURCE: PlanPlus Constantly Crashes Outlook
I was having the same problem. I launched outlook in safe mode. start run outlook /safe. After starting outlook went to the help menu and selected the about microsoft outlook. Click the disabled addons button, enable the the planplus plugin. Close outlook and open it normally. this fixed this issue for me.
