My first suggestion is to unplug it for 1 to 2 minutes then plug back in and see if it clears the code... second may be to do a FACTORY RESET.. Press and hold the "Temperature" and "Dryness" buttons simultaneously for 6 seconds.
I can't find a E60 code in error code manuals for that model.
The circulating heat fan has failed, you will require a repair engineer I'm afraid, hope this helps
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
SOURCE: Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Hi I have a Brother HL-6050D/N Error E60
E60 says the fan is not working, I would try first to blow it out, and after that look for a replacement fan.
