Electrical Supplies Logo
B
Bill wood Posted on Dec 31, 2017
Just bought a mishto generator 4.8/4kva .wont run a caravan aircon.Whereas a Yamaha 2.4 Iva will..The Mishto. Stalls dead .What is wrong.
4 Related Answers
Anonymous
  • 17 Answers
  • Posted on Apr 21, 2012
SOURCE: mishto ct 312 plasma cutter wont cut
not only earth problem, change electrode, nozzle and cathode
Anonymous
  • 1010 Answers
  • Posted on Mar 29, 2013
SOURCE: Mishto plasma cutter and tig not working, there's no arc across the points, there was a good arc when it was working.
check fuse, or other loose connection
  • 19187 Answers
  • Posted on Jan 22, 2017
SOURCE: is the mishto 300 welder anygood
Light duty 60% duty cycle.
Bill Boyd
  • 53816 Answers
  • Posted on Apr 17, 2017
SOURCE: i brought a mishto cb330 car battery charger its not charging my car battery its been on charge all nite the green indicator on the battery has not lit up yet or am i using it wrong.
possibly
the charger leads ( red and black) have to be connect correctly
red to the positive+ terminal of the battery and black to the negative - to the battery
if they were wrong , you may have to replace a fuse in the battery charger
Where is the fuse box located on mishto 165 litre 12 volt fridge
The Mishto 165 litre 12 volt fridge may not have a fuse box. However, there may be a fuse located on the power cord or near the power source for the fridge. If you cannot locate the fuse, it is recommended to refer to the user manual or contact the manufacturer for assistance.
2answers
I have plugged in my new mishto 165 litre fridge freezer only to find it will not work on 12 volts
Is is multi-voltage, they all appear to be. Did you read the manual?
165L Portable Fridge Freezer 12V 24V 240V For Camping ...
https://www.ebay.com.au > itm
Type 165L Fridge Freezer. This Mishto Portable Fridge is perfect for outings, keeping your food and drinks chilled. It has a practical design, ...
https://www.google.com/search?q=mishto+165+litre+fridge+freezer
Manual for Mishto fridge freezer
Where is fuse located on mishto fridge
Have hard wired a spool gun to my mishto welder feed works gas works bur no power for arcing.
connect the + lead to the spool gun so that there is power at the end of the wire to make the arc
there should have been a user manual showing how to connect it into the system
try searching -- user manual for ( make and model of ) spool gun
Mishto plasma cutter won't work
You need to check the power supply, the air pressure switch.
Top Yamaha Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
