Please find below a link for a multi instruction manual.
match the dials and pushers and use the manual.
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwinlOKtz7nYAhXJJcAKHTQ1AVMQFggnMAA&url=https%3A%2F%2Fimages-eu.ssl-images-amazon.com%2Fimages%2FI%2FC14w6u0c62S.pdf&usg=AOvVaw290bGYWoeQCSaX-VEyQdtS
Regards
SOURCE: need instructions to reset sub dials on Nautica Chronograph watch
Pull out crown to the first click and push and hold pushbutton at 2 or at 4.
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
SOURCE: I just recieved my Movado
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
SOURCE: i have a michael kors watch with three dials. one ...
Pull out the center dial. It has two stages when you pull- first is to adjust the day, second is to adjust the time.
