Just a thought. Is the belt tight or does it slip when you put pressure on it. Check and see if the impeller outfit is plugged. Mine did that and it was plugged with an old shirt I picked up in the snow. Can you turn the impeller by hand when the engine is shut down. If so could be a shear pin broke off in the impeller.
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Testimonial: "Thank you for the quick response."
SOURCE: How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
