SOURCE: power light went out and won't come on. Hasn't
wii control doesn't turn lights on. if you twist it a bit, the lights go on. must have something a bit los inside. no tec service here
SOURCE: I can't get the hand to show up on the screen.
Check to make sure your light-bar is plugged in securely (the thin sliver bar that you put on top or below your TV). The wire for this is quite thin, so make sure there are no punctures and cuts in it. I hope this helps!
Here is a link to Nintendo support:
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Here is their support phone #: 1-800-255-3700
SOURCE: My Wii RVL-001 will not
check these things >>> 1.check ur power cable
2.check whether u have inserted the disc properly and precisely. 3.check the
insertion of memory card... 4.check the video port.......
still the same problem,dont worry check out the
following Repair Guide....
click here to download repair guide
SOURCE: I can't connect my controller
SOURCE: Where can I find a user manual for my Wii RVL-001 (USA)?
These work for all type of wii models
http://gamesites.nintendo.com.au/support/Wii_Operations_Manual-SystemSetup_AUS.pdf
Thanks
1RepairStop.com
