Need to change hour, minute and date
SOURCE: need setting instructions for date,alarm,etc on my timex expedition
http://assets.timex.com/manuals/index.html
Here is the link for all Timex watches and the appropriate manuals.
This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
SOURCE: I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
SOURCE: how do i change my timex wr30m from 24 hour to 12
Hi cbrichw,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3.
Press the "Change Mode" button on the lower left to set the hour. The
hour will flash. Press the "Date Advance" button until the correct hour
is displayed.
4. Press the "Change Mode" button again to set
the correct 10s unit (first digit 1 or 0) for the minutes. Press the
"Date Advance" button until the correct first digit of the minutes is
displayed. Repeat this step to set the second digit of the minutes.
5.
Repeat Steps 1 through 4 of this section to set the year, month, date
and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
