Timex indigo expedition
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
SOURCE: need a glass for my timex expedition watch. What
No problem with it. Any watch repair shop will order exact size glass for your watch and will fit it. Fitting is easy if you have special glass fitting press. No way to replace watch glass without this tool. Visit your nearest watch repair shop and ask for new glass. Rate me,plz.
SOURCE: How to set the alarm for the Timex Expedition
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, plz.
SOURCE: Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
My chrono settings will not reset back to 0.
SOURCE: replacement watch band web site?
mcdevito75 here, Timex.com should help. Also look for a small watch repair shop in your area for a replacement strap, and they may even have faster accesss to Timex.
