SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
SOURCE: I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
SOURCE: Access to burner on Frigidaire Affinity AGQ6000 series dryer
you do have to pull out the unit and use the rear access to unscrew those screws accessable from the inside.
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
SOURCE: I have a Viking Gas 30
Viking manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
