Manual Reset Waste Ink Counter Pad Canon MPC190,
1. Enter SERVICE MODE By pressing Menu, Copy, Scan, Copy, Copy
2. Select TEST MODE.
3. Select 8 PRINTER TEST in TEST MODE.
4. Select 3. [EEPROM CLEAR].
5. Select 0. [INK COUNT].
6. Press the [Set] key.
7. Press the [Stop/Reset] key (returning to the state of 3), and then press the [ON/OFF] key.
SOURCE: how can fix the problem with my canon mp 190
That error is telling you that the ink absorber inside is full. You need a shop to replace that because you need to use Canon diagnostics to reset the error code.
SOURCE: GETTING ERROR CODE E27, INK ABSORBER FULL
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
SOURCE: resetare canon mp 190
ai incercat sa tii apasat butonul STOP, mai mult de 5 secunde? Ce eroare iti apare?
SOURCE: CANON MP 190 PROBLEM E27
Causes : Error 27 is caused by ink absorber tank full Solution : Go to www.youtube.com/watch?v=KcSyC7lKbGQ and Download the video... thanks
