Question about Polaroid Office Equipment & Supplies
I cannot open the photo compartment for the film cartridge on my polaroid one step close up. When I slide the toggle forward it doesn't release. Help!
6ya staff
SOURCE:
Anonymous
  • 625 Answers
SOURCE: polaroid one step close-up
you'll need to get into the guts of the camera and see if the shutter release is jammed. pressing the button closes a switch that advances the print motor and a cam that stops the motor when one print goes through the rollers.
Posted on Jun 05, 2008
Anonymous
SOURCE: Polaroid Camera Film
Throw away the camera and buy a digital one.
Posted on Sep 10, 2008
Chris .
  • 14 Answers
SOURCE: Help with Polaroid 600 film choices & how to use One Step Cameras
the flash will work when you put film in. the film has a battery and the camera works off the battery in the film. the arrows make the picture dark or light.
the polaroid spectra onyx made in 1987 is a totally sharp and beautiful looking camera. you also can put filters on the front of it. this camera was used by law enforcement many years ago so it is made very steardy and well. i own one myself and the pictures are perfect everytime. look this camera up on Ebay, you will not be disappointed.
also, here is a website for you to look up film information
polaroids.theskeltons.org
this website will have everything you need and more
Posted on Jan 18, 2009
Anonymous
SOURCE: Polaroid One Step Close Up film cartridge won't come out
just pull as hard as you can i had the the same problem
Posted on Apr 16, 2009
Anonymous
  • 33 Answers
SOURCE: Sx-70 is Not Ejecting FIlm When Taking Picture
Possible you got a bad film cassette. In the original Polaroid camera packs they had batteries which actually powered the whole camera. The batteries may be dead or not have much charge in them. They are good for a couple years and as you indicate the expiration is up in another month... Good luck
Posted on Aug 05, 2009
Where is the battery located in the Polaroid 600 Close Up camera?
The battery is located in the film cartridge. To replace the battery, replace the film cartridge.
Apr 05, 2013 | Polaroid One Step Close-up Camera--- 600...
Ink cartridge doesnt any help
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on.Figure 1: Press the On button to turn the product onc00442142.gif1 - On buttoncaution.pngCAUTION:If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One.Figure 2: Open the access doorc00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.Figure 3: The print carriagec00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper positionc00442144.gif1 - Print cartridge slot for the tri-color print cartridge2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Step two: Install the new print cartridgeBack to top
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.Figure 5: Remove the tapec00442146.gif1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tapecaution.pngCAUTION:Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Insert the print cartridgec00442148.gif
  3. Close the print-carriage access door.Figure 7: Close the access doorc00442149.gif
Step three: Align the print cartridgesThe HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. Use the following steps to align the print cartridges from the control panel.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray, and then press OK .
  2. The HP All-in-One prints a print cartridge alignment sheet.note.pngNOTE:If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
  3. Lift the lid. Place the top of the alignment page face down in the left front corner of the scanner glass. Close the lid.Figure 8: Load the alignment sheet on the glassc00443602.gif
  4. Press OK to begin the alignment.
  5. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Oct 28, 2011 | HP Officejet 5610 All-In-One InkJet...
How do i load the film
There's a sliding catch on the left side of the camera (as viewed from the front) at the forward edge. Slide it and the lower front panel drops down to reveal the loading slot. Insert the photo pack (you may need to remove an old empty photo pack first).
If the new photo pack is an original Polaroid one, then because they are all so old and far out of date then you may find that the battery is totally dead or has just enough power to eject the cover slide and perhaps one photo. If that is the case either convert your camera to accept an external 6v dc power supply before using the expensive photo pack or buy a freshly manufactured compatible pack from The Impossible Project.
May 04, 2011 | Polaroid One600 Pro Instant Camera
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    How do you get the ink cartridge out of the printer
    1. Unplug your Kodak Photo Dock's power cord. Pull the black tab on the right side of the printer down to open the ink cartridge door.
    2. 2 Push up on the green cartridge release tab in the upper center of the ink cartridge to release the old cartridge. Pull the old ink cartridge carefully from the Photo Dock.
    3. 3 Rotate the new ink cartridge's ribbon wheel on the side of the cartridge clockwise with your finger to remove any slack in the film. Do not rotate the wheel too much---this will damage the cartridge.
    4. 4 Insert the new ink cartridge into the Photo Dock with ribbon film facing down until you hear the cartridge click in place. The ink cartridge will only go in one way.
      Do not touch the ribbon with your fingers. Handle the cartridge by its edges.
    5. 5 Close the ink cartridge door and plug in your Kodak Photo Dock's power cord.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Aug 26, 2010 | Kodak EasyShare Printer Dock Series 3
    How do you place cartrige in printer
    Step eight: Install the cartridges
    1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
    2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
    3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
      • Slide the tri-color cartridge into the left slot.
      • Slide the black or photo cartridge into the right slot.
      Figure 7: Insert the cartridgec00830211.jpg
    4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
    Aug 08, 2010 | HP Officejet 5780 Printer
    How long do polaroid cameras last - the old versions, eg 600
    These cameras have the battery built in to the instant photo cartridge; every time a new cartridge is loaded the camera therefore gets a fresh battery as well.
    Stored in cool, dry conditions the cameras will last a very long while. I've owned one since 1978 and last used it around 1983 but when I ran a film pack through it last year it worked perfectly.
    The only thing which may cause a problem is if the grease on internal moving parts dries out, but there aren't many such parts, just a motor and very simple photo eject mechanism. Not like the myriad of tiny precision parts in a regular film camera which may jam under such circumstances.
    In short, the most of the remaining Polaroid cameras should long outlast the availability of the instant photo packs which are no longer in production and which do not stay fresh forever.
    Regarding the issue of "the light is not on when i open it" you'll need to state which exact model you're referring to and which light. The only one which I'm aware of was the flash ready light on the later models which had a built in flash forming part of the camera lens cover.
    Jun 10, 2009 | Polaroid 600 Film Camera
    BMW X 3 Panoramic sun roof initialization.
    title says X5, but description says X3. i'll explain for an X5, but X3 with the pano should be the same. and i'll explain function of the roof, not reprogramming.
    button is located on the panel at the top near the front & center windshield. its the switch on the far left on this panel. its a switch that not only toggles, but also slides forward & back.
    with your finger in front of the button, slide it back & release. this will make the cover slide back and store revealing the sun roof. you know have 2 options (tilt the sunroof up or open the roof completely).
    to tilt it up, press up on the rear of the button and release. the rear of both roofs will pop up. to close, push up and release the front of the button or slide the switch forward.
    to slide it open completely, repeat what you did to open the protective cover (slide the switch from front to back). the roof will open completely and stow out of the way. to close, slide the switch forward and release. pano roof will now close.
    to close the cover, slide the switch forward again.
    neat trick: if you want to tilt the sunroof open without opening the protective cover, press up on the rear of the button (when the cover is closed) and release. the cover will separate in the middle exposing about a 2-3 inch mesh, then tilts the sunroof open. to close, push the button forward again.
    also, if you are above a certain speed (can't remember what it is off hand) with the sunroof open or tilted, it will close automatically, then perform the neat trick on its own to keep air coming in.
    one last trick: if you want to open the windows and sunroof from outside, press & hold the unlock button (forward button on the key) and you will see the windows go down, then the roof will open to vent. releasing the button will stop the motion of the windows & roof.
    hope this answered what you were asking.
    Jan 27, 2009 | 2005 BMW X5
    Look to the upper edge of the slot that the film is in. You should find a thin black lip that flaps. Pull on it to remove the empty film box.
    Jan 19, 2009 | Polaroid 600 Business Edition Instant...
    Polaroid one step 600
    The battery is included in the film pack. If you open the film door you will see the battery contacts in the lower side of the compartment. These line up with the battery holes (looks like foil in the holes) in the film pack. If you have an old film pack and no power the battery in the old pack may be dead.
    May 29, 2008 | Polaroid One Instant Camera
    Top Polaroid Office Equipment & Supplies Experts
    Ekse
    Joaquim Martins
    Andrew Taylor
    Andrew Taylor
    Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
