SOURCE: 763 bobcat The light for loader control is on but
if you push the Push bar forward/up slightly does light go out ? if not you have a bad or missadjusted pushbar switch
Pushbar/Lapbar= thing that keeps you in your seat .
also i don't know your ser # but this model might require the seat belt fastened too, and i can not begin to tell you how many times i've been callled out to site for no "GO" to find MUD in the seatbelt reciever , a shot of brakeclean fixes it right up
SOURCE: How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Testimonial: "I did remove three of the hoses at one time simply two of the hoses were rubbed through and to remove one of the ones I had to remove another to get at one rubbed through. However I am 100% sure they are installed correctly because only two of the hoses are the same diameter and they run parallel to each other and one has to be installed before you can install the other. Thank you for your help. I see I need to get more hydraulic fluid as my level went down after trying system. Joe"
SOURCE: Have a 763 bobcat n right side wheels won't go forward any ideas on what this might b??
Broken chain in drive line on right side or chain sprocket.
SOURCE: 1998 bobcat skid steer 763 has a surge problem
on a 1998 bobcat 763 y
There adjuster bolts on either side of the control levers. To access these you must focuse. Your attention to the bottom. Of control......turning the adjusters left or right will
Excellerate or decrease the drive speed.of left or right traxs or tire's
