SOURCE: MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
SOURCE: Minn Kota Maxxum Trolling Motor
I had the same problems with my 70lb, my motor just quit while on the lake, took it to a minn kota service repair shop. I had two issues. One was the little magnet under the button on the foot pedal got recessed to far down, the tech told me if it happened again pop the button off and pull the magnet up some. Simple fix. I took it home put it back on the boat and nothing just a slight ticking noise heard from the pedal with no prop movement. So I thought maybe somethin was wrong with one of my batteries. Unhooked everything, tested both of them, all good. Even though there was hardly any corrosion, I clean everything, hooked it up and "WALLA"! Power! Problem solved, for now. Waitng to test again out on the lake
SOURCE: Why does my 65lbs minn kota maxxum not run quite?
Fishing string on shaft, runing while out of water(will burn up seals so fast), bent shaft, off balance prop, bad rotor in the electric motor. lots of variables. I bought one that was noisy out of the box, vibrated very bad from the get go
SOURCE: need a shematic of minn kota maxxum 55 lb bow
the pin that holds the handle up broke, Is this a big expense to fix?
