SOURCE: Dishwasher does not run
I'm a hobart tech and repair these units often.I can tell you this---If you open up the control panel and see water the wash tank has a crack in it.If this is the case depending on the serial number you may be able to get a new dishwasher.What happens is the water gets onto the electronics and shorts out.What is the exact serial number,model number and ml number?How old is it and where are you located?Have you had any repairs done by hobart or any other service company?
SOURCE: HOBART FX-20 dishwasher out of order
There is one glued to the lower panel on the inside. Hobart is very tight lip'd when it comes to getting any info from their web site. Best I can do, sorry.
SOURCE: The display on the hobart am 15 dishwasher when
Check thte drain hose as it might be clogged at the entry point to the drain if it connected to a garbage disposer.
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Testimonial: "Turns out it was mice eaten wiring."
