SOURCE: LCD Screen is White
The ribbon cable you require is here:
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1228041&query=Samsung%20VPD351&model=VPD351&path=98821,112905:98830
SOURCE: Black Screen on Capture mode
I contacted Nikon and here is what their email said:
"There is no service advisory in place for a stuck shutter. You can have the camera checked at service and if it is deemed to be a warranty issue then it will be covered. "
Murwilumba, your advice is worthless BS!
SOURCE: my gameshark pro. v 3.3 wont work
you are gonna need a small phillips screwdriver, and carefully take it apart. keep track of the parts. you will need tips some peroxide a dry cloth. you got to thoroughly clean every copper contact .take your time it will work.
SOURCE: Computer monitor screen stays black
check secondary power supply budged capacitors and apply fresh solder. check also lamps connectors.
SOURCE: Leapster screen not responding to the stick
If you don't see any X's then you have to clean the screen very well with some Windex and dry it well. Take any crumbs out of the screen edges and then "milk" the screen with the thumb gently. What happens is that the digitizer gets pressure areas built up so you want to dislodge it. You might need 3-4 "milking" tries. By milking I mean pressing on the screen with the thumb (gently) till you see the screen "bleed."
Also after this align the screen.
