I actually found this on fixya site, hope it helps you: E40 relates to the door being left open when the program is started, it maybe that the latch was not pushed over when the door was shut.After the door is closed again the fault should go away. If it does not and you hear a lot of clicking from the door lock you may just have a door lock at fault.Code E40 is door not closed, could be a misaligned door or faulty door switch.-------But if door is closing properly and you are confirmed that door is getting properly locked, then other possibility can be gunked filter or blocked drain pump.It requires cleaning internally.The procedure is as follows:--- Towards the bottom right of the machine is a pull-down flap.
Drain the machine - there's a tube at the bottom of the machine
with a plastic plug - you'll see a butterfly handle, pull hard; the plug
is a round ball on the end of a stick.
Unscrew the large diameter thing (pump cover) -
Don't do this before the drain step!!!
Withdraw the filter cylinder and remove any gunge - the
filter port has two ports - the left one is the impellor
pump and the right one is the discharge pipe; feel to ensure
these are not gunged up either.
Reassemble in reverse order - as Haynes say.
Almost every programme necessitates a pump activation to
assure that the machine is empty of water
HI Mike.
THIS IS ALL I COULD FIND OUT.
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.
to solve the problem get another switch.
hope this helps you.
or read up some more at this link.
washing machine AEG Lavamat turbo 16800 it displays E40 Google Search
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
SOURCE: My washing machine AEG lavamat
1) Hold in the Pre-wash & soaking buttons TOGETHER;
2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up.
3) turn the knob anti-clockwise to "energy saving"
4) Machine is reset and the door release clicks.
Switch your machine off and then back on again.
SOURCE: AEG washing machine error code
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.After the door is closed again the fault should go away. If it does not and you hear alot of clicking from the door lock you may just have a door lock at fault.Code E40 is door not closed, could be a mis-aligned door or faulty door switch.-------------But if door is closing properly and you are confirmed that door is getting properly locked, then other possibility can be gunked filter or blocked drain pump.It requires cleaning internally.The procedure is as follows:---
assure that the machine is empty of water .-----------
