Yes, I have the same proble.
Wholesale VIZIO DPS-200PP-190 2950318703 POWER SUPPLY UNIT ,cheap price ,and orginal board ,good quality
https://www.abctay.com/vizio-dps200pp190-2950318703-power-supply-unit-p-1644.html
Power board isn't the issue. Its the digital board and/or bad panel. As much as I love to repair things, Vizio is one company who isnt worth it. I have seen 14month old TVs with bad panels. The E470VL is a known problem TV. The panel is probably shorted and its keeping the digital board in protection which is keeping the power supply from starting. Its really frustrating. I wish Vizio would stop making such sub-par equipment.
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
SOURCE: vizio gv47lfhdtv10a no picture no sound
Well guru way to help him out with his problem maybe he doesnt have the money to just run out and buy a new one...
SOURCE: My vizio plasma tv quit, Problem with the
Check ur power source with other devices?Yes.Than,the power supply board it dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
