Read the online manual:
https://www.manualslib.com/manual/291570/Lexmark-Prospect-Pro205.html
SOURCE: foam fell out of printer now printer jams
There are no foams inside the printer for normal operation. Unless this is the one that was inside it during shipping but you were not able to remove it. In any case if you are not having any problems then you are good to go. dont worry about it.
SOURCE: Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer.
2. Turn Printer around
3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel
4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully.
5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
SOURCE: Office Jet pro L7500 paper jam - how to open printer?
hi!!! in your case my advise to you is to open the duplexer located at the back of the printer and look if there's a stock paper or any material that can cause paper jam to your printer.
SOURCE: Paper Jammed.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Your printer and the devices trying to print from it should be connected to the same network. If it is, download our LexPrint app to your iPad http://bit.ly/IMbDlq. Since the Lexmark Pro205 is not AirPrint compatible, you would need the LexPrint Listener installed to a host computer.
Our latest Inkjet printers are already compatible with AirPrint.
