We took off the casing to clean Grandpa's vintage Electric Razor and when we removed the trimmer plate, the spring came out as well. We have no idea how to re-attach it. Please help.
I struggled with this for a while too till I found a diagram. Place the wire spring and the flat detente spring (all the way to the bottom of the slot) in as shown in this diagram. When the trimmer plate goes all the way in, the spring will snap into its correct final position. Lee
SOURCE: My Braun 5564 electric/rechargeable razor will no
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
