Stop top works. Clock and oven clean works. Broil and Bake do note - get F14 Fault. How do I access control board
SOURCE: Installed a new electric wall
I called the place where we bought the oven and after 1 toll free call with many options to go through and talking to three different women I was able to talk to a repair person who ended up being 25 miles away! Since this was on a Saturday he came out today and all it was was a loose wire!! Thanks for getting back to me. Lorelee
SOURCE: F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
SOURCE: Jenn-Air range SVE47600W control panel is
We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
SOURCE: I have a two ear old Kitchenaid gas range
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
