Question about Nautica Watches
How do you remove the back of my nautica watch to replace battery
    Top Expert:
  • Nautica Master
  • 55,370 Answers
Take your Nautica watch to a jeweler for a demonstration of how to remove the back. You might be able to persuade the jeweler to install a replacement battery.
Posted on Dec 14, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: manual nautica watch
I cant aline de hands in 60 line both hands
Posted on Nov 17, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
David Tolond
  • 2501 Answers
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: replacement band for my nautica watch N17524G
Follow this link and contact Nautica: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Rate me plz.
Posted on Mar 04, 2010
Testimonial: "excellent work ! thanks a lot !"
How do i remove the back of my nautica wrist watch to replace its battery
You don't, you take it to your local jeweller who will remove the back and put in a new battery for between $8 and $15 depending on the type of battery, silver oxide or lithium. All done whilst you wait or shop.
Dec 13, 2017 | Nautica Watches
Need new resin watch strap for nautica N19512 and battery
NAUTICA REPLACMENT BAND http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562 Items for sale from bluss 929
Feb 12, 2014 | Nautica Watches
N19512 nautica watch
GO TOEBAY.COM AND SEARCH NAUTICA REPLACEMENT BAND 100% ORIGINAL
Dec 25, 2012 | Nautica Watches
What its a number to battery for nautica watch n09530?
Best way to make sure you buy the correct battery is to open the back and check the # on the battery. You may need a magnifier to see the # clearly. If your changing it yourself be sure to use a blunt, non-metallic tool to remove and replace the battery.
Mar 08, 2011 | Nautica N09530 Watch for Men
I want to buy wristband for my nautica n 135 30
This is a proprietary fit band. Only the manufacturer carries the band. You will want to contact Nautica's watch department customer service directly at:
custserv@timex.com
Nautica watches are produced by Timex, so this is the correct email.
Specify the model number, serial number, band number (if you see one on the reverse) and request price and availability for the band.
If the band is not available, they may be willing to offer you a new watch as replacement.
Feb 04, 2011 | Nautica Resin Round Chronograph #N14537G...
How to change the strip of my nautica watch?
mcdevito75 here, You"ll most likely need a special tool called a spring Bar remover to remove and replace the strap. Best Bet, look for a small watch repair shop in your area for the new strap and it"s replacement on your watch.
Oct 23, 2010 | Nautica A31503 Watch for Men
Watches Logo
283 people viewed this question
Top Nautica Watches Experts
Janelle Schoonover
Janelle Schoonover
Jerry Greenberg
Jerry Greenberg
leadfoot44
Are you a Nautica Watch Expert? Answer questions, earn points and help others
