Cooktop model no. is JP34OBOA2BB. When the electrical element glows orange, the cooktop surface does not heat up.
SOURCE: Maytag CSE9000 Electric Cooktop
They may stay on until the burners cool off. To indicate a hot surface.
SOURCE: RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
Cheers.
SOURCE: burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
SOURCE: ge electric cooktop element switch
Could you please give some more details on your problem isnce it is not very clear.
SOURCE: Replacement solid elememt burner unit for my Dacor ECC46 electric cooktop
Have you try this link
