Washing Machines Logo
allen lee Posted on Dec 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace brake pads speed queen washer model AWS44NW
Lollo Pop
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 134 Answers
  • Posted on Oct 31, 2018
Lollo Pop
Expert
Level 2:
Cheetah:
Answers
134
Questions
0
Helped
73718
Points
301
Cut 3 pieces of wood a bit thicker than the new pads.
Jam then in the brake to relieve the pressure on the pads.
Undo 1 or 2 screws holding pad and pull out.
Reassemble reverse order
5 Related Answers
Anonymous
  • 156 Answers
  • Posted on Feb 25, 2008
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
Anonymous
  • 1294 Answers
  • Posted on Mar 06, 2009
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 26, 2009
SOURCE: Replacing broken belt Top Load Speed Queen
give model number
Anonymous
  • Posted on Jan 13, 2010
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Anonymous
  • Posted on Jul 12, 2012
SOURCE: Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
How to replace the brake pads on a speed queen washer modle aws44nw part # 735p3
hi Allen.
if you go to this link it might help you to find out how you do it,its all i could find on the internet.
How to replace the brake pads on speed queen washer Google Search
Speed queen washing machine fills water but does not agitate but all other cycles spin and rinse working perfect. i took out the belt and started the cycle and the motor was moving fine.
the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
I have a top loading Speed Queen. The drive belt broke and I need to replace it. How do I remove the outer metal cover to get to the working parts
there are 2 5/16 screws located at the bottom of the front panel. Remove the screws and pull the front panel away from the machine on the bottom.
2answers
Excessive lint on all black clothes. All clothes are brand new. Purchased (new) only 4 MONTHS OLD.
Read users manual check spin speed, and water level, usually this is caused by the wrong spin speed or overloading the washer
Speed queen top loader
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
T
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
