To get the green power light to come on for a Brada mf 183 upright freezer, you should first make sure that the freezer is plugged in and that the outlet is functioning properly. If the outlet is working correctly, try resetting the freezer by unplugging it for several minutes and then plugging it back in. If the fast freeze light is still on, it may indicate an issue with the temperature control or sensor, and it may be necessary to contact a professional for repair or replacement.
It is usually reccomended to let it stand in it's normal position for 24 hours prior to running to allow any oil to run back to the compressor. Unit should work.
