I am in Canada and 'Nova Scotia' should be a Canadian brand but I don't know it (I am in Toronto). The model number also appears to be assigned to a company called 'Norfrost'. There are universal seals by size, or you can make your own.
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
There should be a few screws to change. They are covered by a smll plate to keep it looking tidy. Just pop the plate off and replace it. I am assuming you are going back with the original parts.
I have the same problem. Could be 2 things. 1) The top lid may not be all the way down sealing. I had to out some weights on top to make it seal better.
2) The lid seal could be cracked, partial missing or just not sealing. Good luck trying to find a new seal. I'm still looking.
5.5 Cu. Ft. Chest Freezer
Click to Enlarge
Lowest price:$179.00Description: Food
storage will be a snap with this roomy 5.5 cu. ft. chest freezer,
featuring up-front temperature control, storage basket and defrost water
drain.
Good day,
Almost all chest freezers have the condenser coils embedded in the outer walls of the machine. Usually front and sides. They are non-serviceable.
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
