SOURCE: I changed the hoses on my western sonw plow today
off the (joy-stick) in the cab, can you hear the hydraulic motor run when it's set to move to the left???,if so when you changed hoses,did you have all plow angles and heights "centered" when you did this? you may still have a lack of hydralic fluid to that position,does it try to move that way (jittery)?if so, again check for an air pocket in this line and re-bleed the system,overtime it will work itself out of the lines,but you may have it trapped in this hose run
SOURCE: i have a boss plow and no matter where i place the
my friend had simular prblem on a05 chevy and it was a problem with the truk . only happened when the plow was on. the dealer fixed something in the fan assembly and no more problems 4 the last 2 seasons goodluck
SOURCE: fisher minute mount goes up and left and locks up
check your connections, especially the main power plug in, i have used a small "c" clamp over the connection to aid in the same problem
SOURCE: I have a diamond snow plow about 10 years old. It
e 60 snow plow we try to move it up an down to the left it goes to right any where you try to move it
SOURCE: I can hear my fisher plow motor but the plow will not lift or angle
Check/replace under hood motor relay. Spend the extra $2 and get the fisher part. Do not even bother with NAPA junk.
