SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
SOURCE: Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
SOURCE: Where can I find a manual for Husqvarna 450 Rose sewing machine?
I did that, tried to contact the site owner, and never rec'd the manual. What a waste :(
SOURCE: My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
SOURCE: My Viking Rose sewing machine starts and stops and
The Rose has a sensor on the presser bar assembly that is giving you the grief. The machine thinkss the presser foot is in the raised position.There is a small metal flat spring that has gone bad and causing the error. Find an autorized service center to repair the problem.
Testimonial: "Thank you. At least when I take it in they can't fool me into thinking it is something else! "
