SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
SOURCE: The burners in the gas
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Yellow flame and black soot is an indicator that the flame tube is being starved for oxygen. Where the orifice injects the fuel at the base of the flame tube you should find a movable air adjustment shutter that is usually held in position by 1 screw. This screw may have loosened and allowed the shutter to close off oxygen to the flame. Below is a link to a page that shows an oven burner tube...click to enlarge image pn1015233 and observe bottom end. Rotate shutter any direction until a nice blue flame appears but is not "blowing" off the burner tube. Tighten screw to retain position.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1015233&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
