Question about Carrier Heating & Cooling
Our carrier infinity system thermostat heat button broke off. we cant turn the heat on. is there a simpl fx to this?
    Top Expert:
  • Carrier Master
  • 66,248 Answers
YEP REPLACE THE THERMOSTAT
Posted on Oct 07, 2019
    New Friend:
  • 39 Answers
No.replace thermostat
Posted on Oct 08, 2019
6ya staff
SOURCE:
Anonymous
  • 75 Answers
SOURCE: Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Posted on Aug 27, 2007
Anonymous
  • 163 Answers
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
Anonymous
  • 38 Answers
SOURCE: Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Posted on May 07, 2009
kdgrayson
Keith Grayson
  • 195 Answers
SOURCE: Sensor Error on Thermostat for Carrier Infinity System
Either miswired, or incompatible components, or outdoor thermistor isnt installed or is bad
an easy fix if onsite
Posted on Aug 23, 2009
Anonymous
SOURCE: Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Posted on Jan 10, 2010
I have carrier infinity heat unit split system now my thermostat keeps saying comm error
Unplug the AC unit for 5 minutes to see if it will reset and clear the communication error.
Nov 18, 2016 | Carrier Heating & Cooling
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My problem is in addition to moisture near some duct outlets the thermostat always go 2 degrees below the set limit .I also have a carrier infinity system installed only 1 yr, had the problem from the...
if you have a mercury thermostat and it is not leveled properly it will turn the temperatyure on and off by a couple of degrees
some thermostats have the capability of running the unit longer than the set temperature
i would recommend calling a local heating and air conditioning contractor and get the unit cleaned and bring up the issue then
Aug 04, 2009 | Heating & Cooling
Carrier Infinity System Thermostat...The actual temp remains a constant 79 degrees. This seems to have occured after a recent power loss. AC and heat are functioning properly, but must be turned on and off...
Call your local company and check the warranty status on the Infinity UI it should still be under warranty and get a replacement otherwise it could run you a couple hundred dollars
May 03, 2009 | Carrier Heating & Cooling
Feb 27, 2009 | Carrier Heating & Cooling
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
647 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
