SOURCE: LG VU INTERNET AND TV NOT WORKING
you need to set the specs for TMobile and how to add the settings check out this
http://www.mobileslate.com/blog/2009/02/28/lg-cu915-cu920-vu-network-configuration-settings/
read the bottom of the page and it gives the specific Tmobile information
SOURCE: "No signal" on hdtv while trying to watch netflix via xbox
First you need to eliminate the possibility that
the box is loosing video feed from the G.P.U.
hook the unit up in with normal yellow
white and red a/v connection for standard TV
out . if it happens shut the unit off and on again
and if you have sound and no video it's the G.P.U
becoming disconnect , the fix for this is to have
the chip re-flowed back to the P.C.board .the other
cause is a failing HDMI cable but im guessing you
already replaced that.
If you have any questions feel free to ask
Rob
Testimonial: "Very helpful"
SOURCE: modem driver for LG AD 5235 for Apple iBook OS X
kindly visit Authorized service center and they will help
you in this regard.
Thank you.
SOURCE: making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
SOURCE: HOW DOES NETFLIX WORK AND WHAT EQUIPTMENT DO I NEED TO WATCH IT ON TV
I am assuming you are residing in the US. Providing that and that you have an internet connection, you're pretty much set up. Make sure your browser is up to date and will work with Microsoft Silverlight (most modern web browsers do). Sign up for the service or start your free trial. What else do you need to go with netflix? Popcorn maybe?
