Kitchen Appliances - Others Logo
A
Arthur strahan Posted on Dec 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Waeco Mf-1w. Drink cooler 9v Need CFM 9v muffin fan
Bonard Allen
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Dec 08, 2017
Bonard Allen
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
34728
Points
227
The manual for this unit is in German which I had about 48 years ago in college. I suggest you try contacting dometic-waeco.com to find out where you can locate parts.
1 Related Answer
Anonymous
  • 8909 Answers
  • Posted on Jan 10, 2011
SOURCE: WEAR CAN I GET A
Try ebay
Lots of choice there, or browse brevilles web site for a dealer.
Drink o Matic cooler model DR-3. Where can you find a power cord for Drink o Matic Novelty Cooler please?
You should be able to get one from any good electrical supplier, or Amazon based on the socket type which is normally a figure 8 two pin connector.
https://www.google.com/search?q=drink+o+matic+cooler+model+dr-3+power+cord+replacement
My waeco mf 6w my heats instead of cools
Have you contacted the seller? PS, Congrats on your Solar Cells!
3answers
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Can I purchase a new poaching pan for the back to basics muffin toaster and egg poacher?
Yes! West Bend apparently now owns Back to Basics; you can order replacement pans from http://www.westbend.com/finditem.cfm?itemid=3733
WEAR CAN I GET A BREVILLE MF-M5OXL MUFFIN MAGIC MACHINE
Try ebay
7helpful
2answers
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
3helpful
2answers
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
4helpful
3answers
NEED FAN FOR MODEL HVTS18DABB
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be affective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
1helpful
I have 550 CFM cooler and the air is blowing but
you need to open up and clean the pump unless gravity fed but still need to cleaned. or new pump.
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
