SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: regarding microwave
Dear Sir/Mdn
My microwave is running but not heating food,model R-248J(S),S/No: 070737958,I hopw i will get better solution ,thank You.
Aung Aung
HP: 65-90468925
SOURCE: kenmore microwave model 665.68681891 runs but won't heat
Test the high voltage capacitor,
the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed
discharge before testing, or you risk to get electrocuted, even if
power is off. Capacitors can get discharged by shorting their two
contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
SOURCE: My Kenmore Microwave Hood Combination Model
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
SOURCE: MIcrowave doesn't heat up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
fdyjhd
