Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor will not start.
Battery is good fuel is good. less that 1000 hrs
  • Dick Olson Oct 23, 2018
    The most common cause of this problem I have run into with this symptom is a restricted main jet in the carburetor. ethanol fuel (oxygenated fuel) cause a corrosive build up which plugs up the jet. A quick way to determine this and eliminate the ignition, is to remove the air filter and spray a short bust of starting fluid in the opening to the carburetor. Try starting the engine. If it starts then dies it is most likely a restricted main jet. Removing the carburetor, disassembling and soaking it in carb cleaner for 24 hours should do the trick. To avoid this problem, look on the internet for Non-oxygenated fuel suppliers", There are most likely several stations in your area that carry it in one of there pumps.
    Master:
  • Craftsman Master
  • 653 Answers
Are you getting spark to the plug(s). Check with spark tester. Is fuel getting into the cylinder(s)? When it turns over, do you get a spit or backfire? If yes, check flywheel for key.
Posted on Dec 13, 2017
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 48 Answers
SOURCE: lawn tractor w/less than 75 hrs. usage-engine seized
with only 75 hrs isnt it still under warrenty
Posted on Oct 17, 2008
Anonymous
  • 97 Answers
SOURCE: oil light blinking
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Posted on Mar 17, 2009
My 2015 21hp Simplicity lawn tractor is backfiring constantly.
Could be just a carb adjustment. But being a new machine with 50 hrs you probably need the valves adjusted . New machines usually need a tweak on the settings, this is done by adjusting the valve hight and setting the timing. Ps. On all small engines use supreme (high test gas ) with no Ethel ( biofuel) added. The cheaper grades have 10 percent and down . Bio fuel attacks water and diminishes into a varnish more rapidly then expensive fuels. Since small engines usually sit longer then automotive engines the water attracting properties and faster break down of the fuel will kill an engine faster by gumming up the float bowl, and the carb. Also a good practice to add a fuel stabilizer like seafoam toward the end of the season or in periods of long storage..( 3 weeks). Hope this helps.
Apr 12, 2018 | Cars & Trucks
John deere troubleshooting
sounds like a short in the wireing start traceing wires look for burn or bare wires if not that check voltage at battery start it pull posi off batery check voltage 12.5 13.5 in that voltage rang
Sep 02, 2014 | Garden
Why will the engine turn over but will not start
Person has to be on the seat, battery needs a good charge, fuel has to be fresh ( less that 45 days old) oil level has to be correct. If all that is good, then check that the plugs are firing. If the plugs are good and firing it should run. If no spark you may need a "ignition control box" if your model has it. www.mowpart.com or www.sears/parts will have a parts breakdown.
May 06, 2014 | Craftsman Garden
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a Craftsman LT 1000 riding mower that just quit running. Won't turn over or anything. Manual suggests checking fuse as one of the options. Only problem is, I can't find the fuse! Manual says it is...
Start with the easiest thing first !
1) jump start the battery from you automobile, or install a charger for an hour. This will tell you wether you battery or connections are good.
If it started with the jump, before you replace a battery:
2) clean the cable ends and make sure cable hardware to battery posts are good and clean.
If it started with the jump, then you know the fuses are good.
If it did not start with the jump or cleaned and charged battery,
3) check the in-line fuse. Located between the key switch and the solenoid, in the wiring harness, normally behind the firewall behind the engine, or in front of the dash close to the fuel tank (if the battery is under the seat)
4) some Sears tractors use a 'relay' also located on the firewall.
Note: for now, let's see how this works. Let me know if you need further assistance. It can get more complicated, but let's keep it simple for now. rwvanlue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 12, 2009 | Craftsman Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
107 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
