Washing Machines Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to balance washing machine drum - GE Washing Machines
Joseph Vernice
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on Jul 29, 2009
Joseph Vernice
Expert
Level 2:
New Friend:
Answers
63
Questions
0
Helped
27903
Points
221
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on May 21, 2006
SOURCE: Kenmore washing machine
Sounds to me like you have a worn drive block and possibly a bad spin tube. The drive block can be accessed by removing the agitator first. Next you will need to remove the spanner nut. Now you can remove the basket. Attached you will see the picture of the drive block, I hope if it downloads. The spin tube locks into this drive block with two tabs that fit in respective grooves in the block. If the tabs are worn off the spin tube, that will have to be replaced as well. Good luck,
Anonymous
  • 80 Answers
  • Posted on Dec 19, 2007
SOURCE: washing machine
WASHING MACHINES HAVE SPRINGS ON THE BOTTOM OF THE TUB THAT ARE MENT TO KEEP IT FROM SHAKING, LIFT THE LID BY INSERTING A SCREW DRIVER SIDE WAYS BETWEEN THE LID AND THE FRONT THEN TURN THE SCREW DRIVER, NEXT UNDO THE SCREWS ON THE RIGHT AND LEFT HOLDING THE FRONT ON TO THE MACHINE, NOW IT WILL SLIDE OFF AND YOU CAN SEE THE SPRINGS
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 25, 2010
SOURCE: Even though we have balanced the base of our
  1. Find out the reason for the shaking during the spin cycle. The cause will usually be either a badly out of balance load, or a poorly leveled and set up machine. Washing Machine Ratings Get Accurate & Unbiased Information to Help Make Buying Decisions Easy.
    www.consumer.org.nz/washing-machine
    • Balance the load of clothes by opening the lid, and looking to see if there is a lot more on one side of the agitator than the other, and if this is the problem, move them around, close the lid, restart the spin cycle, and observe the results. You may try repositioning the clothes in the tub slightly more if you original efforts helped significantly.2Try to tip or tilt the machine. If it wobbles when you do, the adjustment screws on the machine's base may not be set correctly, or on older machines, the threads may be stripped or corroded out, causing them to fail.Relevel your machine and insure it is supported correctly. This is done by kneeling down in front of the machine, and rocking it to see which corner seems to be floating, or not in contact with the floor. The leveling screw should be screwed out (clockwise, if viewed from above), which lengthens it, or the adjacent side should be screwed in (shortened), so that each leveler is in contact with the floor.4Use a pair of pliers if the thumbscrews are too tight to turn with your fingers, and spraying the screws with a lubricant may help, also.5Restart your machine when you have made sure all the leveling screws are in contact with the floor.6Use shims to support the machine if the screws have become unusable for some reason (broken, stripped, or otherwise damaged). Shims can be made of almost any resilent, non-degradable material which can be cut easily, like scrap vinyl composition tile, rubber matting, or even plastic margarine container lids.Cut a number of shims, about 3 or 4 inches in width, and stack them under each corner where they are needed, until the corners are equally supported.8Restart the machine and observe your results.
Jenny Theiss
  • 53 Answers
SOURCE: washing machine drum out of balance when spinning.
mine is also making noise during the spin cycle. Just paid $95AUD for the repairman to tell me it needs news bearings and that will be a further $300!
Anonymous
  • 2468 Answers
  • Posted on Apr 04, 2010
SOURCE: washing machine shakes violenly at slow speed
have you leveled the machine by its legs and locked them in place with the jamb nuts between the case and legs? if so then it could be your drum bearings going bad on the inner drum
Does washing machines need to have a minimum weight to wash properly?
No, it just needs to be evenly balanced. For instance, you can wash one pair of underwear if you wish, (although wasteful) and it will wash fine because it is light. If you try to wash one hand towel, it might throw the drum off balance on the spin. However, if wash two towels, it will be fine because they will find the balance spots themselves. The best washing is done with a medium load so that the the washing is picked up and dropped from the top of the drum (front loader), not so critical with a top loader.
1helpful
It shakes excessively on spin cycle, machine is level, it does it on every load, it is beginning to tear up door seal
It shakes when off balance. Your wash load may be balanced but the drum may not be. This could be down to the drum bearing or the "spider" that holds the drum in place. If one of the arms is broken it will spin off balance.
Washing machine tub is banging into the side of the walls..what's the problem here
There are two possible causes for when a washing machine jumps and bangs on spin. Either the load is a bad one and unable to be balanced, or a fault is preventing the machine from balancing the load (or causing the motor to surge into spin when it shouldn't). This causes the laundry to be flung around inside. The occasional jumping around may not be anything to worry about, but regular or severe occurrences should be a cause for concern and can cause expensive damage to your washing machine if ignored.
Both these faults are less common these days because manufacturers have built in certain protections, but it's still something that can happen. To differentiate between the two, observe when the problem occurs, if it's during a wash cycle, maybe at random parts of the programme, it may have a fault which really needs an engineer to diagnose as these faults can be intermittent and tricky to diagnose. If it happens when it kicks into the fast spin the chances are it's related to the load inside.
Am I overloading my washing machine?
By out of balance I mean when the washer jumps or bangs quite violently. If the washer is just rocking about on most spins make sure it's on a level floor and that it is properly level.
If a load is out of balance you can often observe the inner drum swaying about or even thumping the sides of the casing a few times whilst it's trying to distribute the load prior to fast spin. Before a proper spin the drum should revolve slowly for a couple of minutes. This is called "distribute" and at this stage you may see large flashes of metal drum on each revolution where all the laundry has settled around the drum but there wasn't enough to cover all of it. If this happens the drum will be out of balance and either refuse to spin, or if allowed to spin may cause the drum to thump around and hit the sides of the casing.
The best way to avoid unbalanced loads in a washing machine
If you try to wash a bulky, heavy and absorbent item, the washing machine is unlikely to be able to get it to balance inside the drum. Or if you put just a few large towels or a heavy item in amongst some very light fabrics the heavy items could bunch to one side of the drum and the lighter ones won't be able to counter-balance their weight effectively. There should be enough items to fit all around the drum. If there's only enough to fill most of the drum, but a section is empty, then it can get out of balance on spin. If the items are all light, then this may not cause a problem. However, if some items are heavy, they may cause violent banging, or the washing machine out of balance detection may just refuse to allow a spin.
Make sure you fill the drum well. Counter to expectations, the worst violent spins are caused by under-loading - not overloading. Heavy bath mats are notoriously difficult to balance and should ideally be washed with other items or they may gather on one side of the drum. However, some people (understandably) don't want to mix the bath mats in with normal washing. If this is the case and you do get problems with the bath mats getting out of balance I suggest you use old towels or sheets to even the load up. With most modern machines though, a heavy bath mat is more likely to just not get spun rather than be allowed to spin out of control and wreck the machine.
Sometimes you can get an unbalanced load by sheer chance, with loads you have successfully washed many times before. The occasional bad load is inevitable but constant bad loads and violent banging on spin should be looked into. [ Related: loading the washing machine properly ].
Modern washers have built in out of balance protection
Most modern washing machines now electronically monitor the motor during the slow distribution section leading up to the spin. If the load is out of balance, the motor shouldn't be allowed to spin. Typically, a modern washing machine will attempt to balance the load a certain amount of times, or for a certain passage of time, but if it can't, it will either reach the end of the program without spinning, or it will abort spin and turn off. (both scenarios leaving the clothes wet through). Some washing machines may allow a slow spin if the clothes are reasonably balanced, but then unless they settle down, it will not allow a higher spin thus leaving the clothes spun, but much wetter than normal.
Some will indicate a failed spin due to being unable to balance the wash load so check your instruction book to see if your washing machine has this function and what happens if a spin is aborted. Unfortunately some washing machines do not adequately inform the user that it failed to balance the wash load and aborted spin. As an engineer, I have been called out many times because a load was washed but not spun, but there was no fault on the washing machine, just an aborted unbalanced load.
Extra large drums make balancing loads harder
These days you can buy washing machines with much bigger drums. The average drum size was at one time a mere 4.5Kg but is now 6Kg. You can buy washing machines with 7Kg, 8Kg and even 10Kg drums.
These washing machines can be more prone to refusing to spin some small loads because they need even more items to fill the drum. For example, my 7Kg washing machine will not spin 3 large towels. Last week my wife was extremely frustrated with our 7Kg drum washing machine as she had just washed our son's hoody-top and wanted to spin it in the washer. It simply would not spin, so I advised her that it needed something to balance it out. She put in a couple of towels but still no spin. Eventually 5 towels were needed to balance out the absorbent top and allow a spin. This is a minor inconvenience compared to the benefit of being able to fit more washing in (even our king sized quilt) but it highlights how if you have a very large drum it could be more prone to not spinning small loads [ Washing machine won't spin just one item or very small loads ].
I'm loading the washing machine correctly but it still bangs and jumps on spin
This is unfortunately a difficult fault to diagnose. It could be various things including a faulty connection somewhere on the motor or pcb, especially if intermittent. It can be caused by a part overheating, cutting out and then cutting back in causing loss of control. If this fault isn't caused by the loading you really need to get an experienced engineer to look at it. Find a washing machine repairer on Washerhelp
If a brand new washing machine is jumping around on spin
Make sure you have removed all of the transit packaging before using a new washing machine. The transit packaging stops the suspension from working so without the tub being able to bounce up and down on the suspension all the movement created on spin will be translated to side to side movement and the washer will move about and shake.
Loading washing machine White Goods Help washing machine jumps and bangs on spin Washing machine won spin just one item Book washing machine repair
Why washer moves and vibrates all over when spinning
There must be the correct weight in a washing machine. If it is under loaded then the drum will spin out of balance because the weight is trapped to one side. regualar use like this will break the drum bearings.
Weighty things like towles & sheets have to be balanced around the drum prior to spining, that's why the drum does slow and quick spins to even the load out. apart from that one of the drum supports need attention.
Wash machine is off balance
CHECK TO SEE IF W/MASHINE is properly leveled,you can do this with a spirit level,from front to back then side to side,with level on top of machine,then adjust the feet accordingly,if it still does it,check to see if the drum bearing is worn,switch machine off,open the door and with your hand at the top of the drum try and lift the drum up and down ,you should not feel any movement,if there is the bearing probably needs replacing
Washer is out of balance. it just leans to the left side and makes loud noise like metal on metal.
It sounds like your drum support, and/or balance mechanism inside the washing machine has broken. You will need to open your Washing machine and inspect the Drum Support, and the balance mechanism. Hook it back up or replace it if it is broken.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2answers
My washing machine's drum is making a scraping sound when turning
There are two different types of "drum balancers" manufactured into washing machines today... One is a disk type (most washers with this have 2-6 depending on age, manufacturer, and quality), the other type is a self-balancing style. It sounds like you need to order some new drum balancers. The repair will take approxmiately 1-3 hours depending on if the it is a front or top-loading machine.
Hope this helps, James
2answers
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
1helpful
2answers
My hoover galaxy washing machine stops when clothes are not balanced properly.i have to even out the clothes then start the machine.if the clothes are balanced it finishes its cycle.if not the machine...
Hi
It is normal for the drum to sway excessively and hit the balance switch if the load is not evenly distributed around the drum or if you have excess cloths.
Once the balance switch is trigerred, you can reset by openning and closing the door. It is a safety mechanism which stops the spin cycle if the drum sways excessively.
If this tends to happen often, then you need to make sure the machine is properly balanced and not leaning too much to the back.
Also the drum suspension rods do tend to wear out over time and loose their firmness, causing the drum to sway excessively. You can check this by opening the lid. Pushing down and from side to side onto the agitator, and seeing if their is a firm bound on the drum. Also making sure the drum returns to centre position. If the suspension springs feel loose and wayward, then they will need replacement.
Regards
Ash
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin...
most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
