It's possible that either the volume partition has been corrupt.
in which there are data recovery tools that can help, or your drive was formatted on a different os that your machine and is not recognizable. Windows always offers to format a usb when it dosnt recognize the formatting. Just skip that part and run the data recovery tool. Keep in mind, although usb drives are handy, with all flash technology, there's little notice if any , when the drive begins to fail. So always keep a cloned usb stick or alternate data storage when using flash.
SOURCE: USB flash drive wipe out
I went to the Sandisk website and they actually have a bunch of how-to videos on there that will help you out with your problem: http://www.sandisk.com/Retail/Default.aspx?CatID=1459 As for getting your information back, you would need special recovery software in order to do that. Here is a link that might be able to help you with that: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
SOURCE: Verbatim portable hard drive not recognized by XP - works in 2000
Try it is different USB port of your PC. It worked for me.
Farhan
SOURCE: Plug into USB port... recognizes device when I
Is your usb drive locked? The micro vault classic has a lock switch on it. This prevents you from writing data to it. Please make sure that is not in the lock position. Then plug it back into your pc and you can go ahead and format it.
SOURCE: the camera wont load pics onto the computer.
try plugging it into some other USB port and even try uploading the drivers of the USB!! or best is try using some other USB to test it!!
reply and rate!!
SOURCE: can't access data on external hard drive.
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive hope it helps
