Hi there.
not sure if this is your phone as you did not give model number.
but try this.
First method:
More items...
SONY Xperia XA F3113 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/sony/sony-xperia-xa-f3113/
or this one.
Restarting andresetting your device Sony Xperia XA support Canada English
or this.
Restarting resetting and repairing Sony Xperia XA support English
or this.
SONY Xperia XA F3113 How to Hard Reset my phone HardReset info
SOURCE: Lg Cookie wont turn on
You need to re-update (FLASH) Bios. It must have got corrupted. The worst part is that there is no support from LG
SOURCE: it wont turn on or reset or charge
sony.com first you should try this website if it dont help then 1st try to turn it off again, next you should connect it to your computer to try and detect the problem. if thid dont work contact this sony pplz
SOURCE: i have the Verizon LGVX8350R phone, it works
To test if it is your charger, test the same charger you use on another lg phone to see if it works.
If it does not work, then it is the charger that has a fault.
The solution to that is for you to replace the charger.
But if the charger works, then it means there is a problem with the charging port of your phone, it probably got damaged when you phone dropped.
The charging port is the place you plug your charger on your phone.
You can get an extra battery and a universal charger so you can charge a battery while the other is in use.
But if you want to fix it, this is how you fix it;
Take care
