Question about Asrock Computers & Internet
Asrock h110 disable on board video using cards for mining only
6ya staff
SOURCE:
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: mother board - video card compatibility
if you have a built in video on mother board there is a setting in its setup hit delete at beggining right at startup for bios
you need to disable your built in video either by jumpers by manufactures book on jumper settings or go into bios at begining and see if there a setting to shut off on board video
these 2 are having conflicts with each other and you will only be able to see dos boot area with both these cards
and yes it is compatible as long the buses and slots have same configurations
Posted on May 08, 2008
Anonymous
  • 42 Answers
SOURCE: Evo D51c Video
You need to power off the PC, install the new video card, turn on the PC and go into the BIOS and disable the onboard VGA, and set the BIOS to use the new card. i.e AGP slot.
Posted on May 11, 2008
map9966
Mike Peluso
  • 2351 Answers
SOURCE: EVGA e-GeForce 7200GS-Disable motherboard Video
The answer is yes. You need to change the on-board video (Known as PCI), & set it to AGP page 36 in you're manual. This setting will be under Integrated Peripherals.
You will also gain back system memory that the on-board video was taking from you're main system memory for it to work.
At start up of the PC press the delete key every two seconds to enter the bios menu. Go to the Advanced menu & find Integrated Peripherals. There is not a disable (per-say), all you do is set it to AGP. That's it.
Enjoy!
Mike
Posted on May 20, 2008
Morikvendi
Milan Cankovic
  • 56 Answers
SOURCE: want to disable onboard graphics to install and use pci vga card
During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
This will take you to BIOS, main setup panel for your PC.
There you can find and option for switching your main GFX card.
Options will be something like: onboard, pci, agp. You should choose
PCI.
Try doing this after you insert your new PCI gfx in your computer.
Good luck,
Milan
Posted on Jun 01, 2009
rajeshpait
Rajesh Pai
  • 542 Answers
SOURCE: getting on board vga video to work on asrock
As per discription provided by you, Suspect the physical RAM is having problem. Check and insert the RAM properly may solve your problem.
Hope the above solution may resolve your problem. Please give us the feedback on the solution to provide the best resolution in future.
Revert Back for more assistance or clarifications.
Posted on Dec 26, 2009
I cannot set up h110 headset in my windows xp
Just connect the two connectors to your computer sound card.
Your computer should have a pink connector for the mic and a green for the speakers. You also could plug the speaker (headset) into the orange if your sound card has that colour.
Then you just adjust the volume for the headset with the sound settings of the computer.
The program you want to use the headset with, will also allow you to fine tune the set.
Jun 08, 2014 | Logitech H110 Headset - Stereo
Asrock g31mgs no power
You need to set the Bios to default to your video card and not your on-board video or disable the on-board video in the Bios..
Jun 25, 2012 | Computers & Internet
VGA / Onboard graphics Issue
Yes, there may be a problem with the on board graphics, if you have a compatible graphics card you can bypass the on board.
Was the previous owner using the on-board, or did he maybe have a card that he removed? Might be worth looking in the BIOS settings in case the on board graphics has been disabled
Apr 29, 2017 | Asrock 775i65GV Motherboard
Asrock 533 vido card not working
If your using a plug and play video card(placed in AGP or PCIE slot) your built in video out will be automatically disable.Be sure you have checked it carefully.
May 02, 2011 | Asrock P4I45GV R5 Motherboard
No video with or without a new video card on an asrock p4i65gv motherboard
So you can no onboard video when using the onboard connection right? and no video using an external video card also right? In this case, the promblem lay with the motherboard/ram/cpu and not with your video card. Try resetting the bios via taking out your cmos battery or shorting the cmos pin to see if a miracle would happen and the system would post. If not and if you have another board with compatible hardware, then you can try testing out the cpu, the rams. If you hear beeps when starting up the system, try to take note of it and look up on the internet via what bios make it is, and decode the beep error for what is wrong. If you don't her any beep, the other way only to know what is wrong is having another compatible board to test your cpu/ram, or make sure the ram and cpu you are using is supported by the asrock motherboard. If you do have another board to test your cpu/ram and even the video card, and they work, then your motherboard is scrap and needs to be replaced.
Jan 26, 2011 | Asrock P4i65G Motherboard
No beep,No Display on my monitor,only CPU...
Connect the same monitor to anothe CPU if it works, Get an add-on Video card to your systems and disable the on board video card. If your monitor has a problem repair or replace it.
Sep 14, 2010 | Asrock P4I45GV R5 Motherboard
Video not working on 755Twins-hdtv motherboard.
The option to disable the onboard graphics is in the BIOS.
You need a PCI-express card. You should not be trying to fit any graphics cards into the PCI slot.
The VGA/HDTV conection should have been supplied on a seperate card.
Your support page is here http://www.asrock.com/mb/overview.asp?model=775twins-hdtv
Aug 01, 2010 | Asrock Computers & Internet
Mother board - video card compatibility
May 07, 2008 | Sapphire RADEONâ„¢ HD 2600 Pro, Graphic Card
Problem with asrock p4i45 mother board reading agp card correctly
Did you try changing it through your BIOS? Most motherboards with AGP have an option in the BIOS to switch between PCI mode and AGP mode. If this doesn't work, send an e-mail to asrock.com stating the problem and see if they have a patch for it.
Aug 23, 2006 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
75 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
