SOURCE: Got mini split, lost, remote control, bought
Don't know a code for a universal remote, but you can order a new remote from an appliance parts supplier. If you have the model you posted under, the part number would be WJ26X10152 . (about $25) Make sure you have your exact model number from the model / serial number tag off the product to make sure you get the correct remote.
SOURCE: goodman mini split unit condensating and leaking
Hi, your evap. drain is block, i know you are smart, we can do this, remove front cover of evap.(indoor unit) check for location of screws, look carefully you will see drain connection and tray, try to clean, use mild cleaning solvent, or practical way push something flexible into tubing, also clear your air filter, and you'll be in good shape, also check leveling of evap(indoor unit), with spirit level, should be horozontally leved. good luck.
SOURCE: i need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
SOURCE: Broken remote model hg31as. can't find replacement. need to operate manually. How?
I have the same problem, i cant find any replacement for this remote, but you can turn it on lifting the filter plastic cover and looking for a switch at the right center of the console.
SOURCE: I have a goodman mini
To change from Cecilius to Fahrenheit on the remote control, hold both the + and the - simultaneously and this will enable you to toggle between C and F. You will need to do this each time you change your batteries.
