SOURCE: Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
SOURCE: SAMSUNG DLP617W SCREEN GOES BLACK SOUND IS ON CAN"T USE REMOTE
u need the main digital board for this model cost about $250 - $350
SOURCE: th-50pz80u turns off for no reason
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
SOURCE: emachine running SLOW and Freezes - 1 year old
Here are some suggestions: First of all . Do you have an anti virus installed on your husband's machine ? Viruses can slow the machine and even kill it permanently ( so be careful) . Just install an anti virus and you'll solve the problem . If you are already have an anti virus , then just run a full system scan and watch what will happen and follow the recommended steps that will be given by the anti virus [ There are a lot of anti virus softwares in the market ] but if you suspect that your system is already infected i recommend you to use (Avast professional edition) because it can make a boot scan , that means after you install it , it will ask you if you want to make a boot scan , just agree with it and it will reboot the system and start a boot time scanning , meanwhile you should watch it and give it the right orders if it detected a virus infection .
Here is another suggestion : There is a certain software you could install it . This software can help your machine and detect any problem on your husband's computer but viruses . this software is called (TuneUp utilities) . You can download it from here www.tune-up.com . just try it and you'll be satisfied with result .
if that didn't help just contact me again and i'll help you as possible as i can .
good luck .
