The LCD display is working, I can see old images and menu options. When taking a new pic or video the image is black.
SOURCE: LCD Display Flickers
if the replay is OK,the LCD is fine. Then check the CCD that is defective. We can supply LCD and as well as CCD.
SOURCE: Canon A85 - Can't take Pics
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: My Yahoo Messenger display picture won't change
oh i can fix yah !!!!!!!!!!!!!! just go to the c:/ dir and click program files and click the messenger dir and you can see there the uninstaller !!!!!!!!!!! and if you are now uninstall the program and then go to the yahoo website and download the latest ym program ///////////the problem is there might be a corrupted files
try uninstalling all the yahoo messenger in your computer then restart the computer..then try installing the new yahoo messenger the 9.1 i think i forgot but its the new one...now if it srill doesnt work try calling yahoo messenger...
The display being blurred can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
