SOURCE: washing machine does not wash clothes
You are possibly washing at the wrong temp, or not using sufficient powder or detergent.
The m/c is not rinsing properly, check that it is pumping o/k.
If there is a build up off slime and mould on your door seal, then you are definately washing at too low temp.
At least every 4 to 6 weeks, do a high temp wash with powder in but no clothes.
This is called a maintenance wash and helps to keep the inside parts clean..
If your door seal is stained, clean as best you can with a scourer pad or similar. You will not hurt the seal.
plz rate my solution .
Thanks.
SOURCE: smeg washing machine stuck on pause
If the machine won't start then it will most likely be the door latch that is at fault.
