SOURCE: HOW DO YOU REVERSE THE
If the motor is reversible, you will have 4 small leads that have pigtails that will connect to eachother to make the circuit. Usually they are 2 colors and you will either hook up the matching colors for CCW or opposite colors for CW. If you do not have these leads, you will more than likely have a non reversible motor. You can also look at the data plate on the motor itself and it will tell you the rotation. If it says REV. then it's reversible. Hope this helps and good luck!
