Water Heaters Logo
H
Herbert T Ellery Posted on Nov 25, 2017
Will I still have water running to the water heater if I shut off the bypass valve?
Louuis-Marie Veilleux
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Nov 25, 2017
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
12187
Points
75
Bypass valve is to bypass the water heater. No bypass valve and always water in tank. Put a bypass valve and shut it up it is like no bypass valve.Open the bypass and shut up the input (cold water) and output hot water) no running water in heater tank but still have cold water in the rest of the house even in the hot side of the faucet.
5 Related Answers
Anonymous
  • 332 Answers
  • Posted on Mar 06, 2010
SOURCE: My rv water heater ignites, I have a steady flow
If your lighting and not getting hot water then you have a valve closed or your by pass is in the wrong position, if it is burning on gas it will heat water
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jun 02, 2010
SOURCE: where is the bypass valve on the water heater?
Look at back of water heater, valve(s) should be back there. You want valve open to bottom (cold in) and also valve open to allow hot water out at top. Any valves in between, closed.
Testimonial: "Thank you"
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jun 08, 2010
SOURCE: Bypass check valve
Any RV sales and service place should have them.
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jul 20, 2010
SOURCE: When i turn the hot water on fast i here a click
The hot side (top line) should have a check valve between tank and water line. I'd replace it. Be sure you install new one the right way. Stem, spring etc should be facing in tank.
Anonymous
  • Posted on May 06, 2011
SOURCE: RV water heater problem: my water heater ignities,
I have an Antwood. Tank is very hot. Water from hot water taps is slighty wamed. The flow is good. I dont get it.
Myles
RE: Richmond EcoNet shows "Water Sensor Alarm". How do I reset it?
For the water heater leak detection alarm, make sure that there is no water left near the water heater. (Fix any existing leaks.) Then press and hold the Clear Alarm button on the water heater panel for 1 second. You should hear a beep and the alarm will be bypassed for 24 hours. If additional water is detected, then the alarm will be replaced with a service heater message. (Note: there is no clear alarm button on the App or the water heater shut-off valve.) See the manual for one of the Richmond Smart Water heaters here: https://static.globalimageserver.com/site/richmonddotcom/electricwaterheatinglanding/SmartElectricResidentialWHwithEcontrol.pdf . A manual for the add-on leak sensor and shut-off valve is available here: https://hw.menardc.com/main/items/media/RHEEM002/Install_Instruct/AP21850.pdf .
I hope this helps.
1helpful
T and p valve leaking and i replace it and pressure pushes out hot water
It sounds like it's doing it's job, by not letting your water heater turn into a missile, or exploding....The "T" in T&P stands for temperature. When it gets too high, the valve will open. The "P" in T&P stands for pressure. When IT gets too high, the valve will open. When they both get too high...you know the rest...The condition can be caused by many factors.
1. The house "pressure reducing valve" is letting in too much pressure. Any more than 80 lbs. is too much. 50 to 75 is good.
2. Hot water expansion in a closed loop system...no "prv" or "water meter" bypass...To fix, you can install a small "expansion tank" above the water heater. It will allow the extra bit of water to go somewhere temporarily, Letting the T&P valve stay closed. Installation is always on the hot outlet side, because high efficiency water heaters use a "check ball" in the factory installed cold water inlet nipple, which also doubles as a dip tube. (lets cold water into the heater at the bottom)
When a gas fired water heater turns on, there is a pretty fast spike in both temp. and press.
3. The gas control valve itself, has a non resetting 190 degree, "high limit" safety shut off feature. IF that were to fail, the control would run away temperature wise, but I have never heard of one failing.
regards!
1helpful
Water running on floor
your tank is probably going bad in your water heater the shut off valve would be your homes water supply valve.
Having trubble with hot water. It won't run up the sinks or shower only cold water. I own a 2008 keystone everest
Check to see if it has a hot water heater bypass installed,if so the valve is likely in the bypass position...
When i turn the hot water on fast i here a click ( comming from the vacinity of the water heater) and the water stops. This is at all water faucets. Sounds like a check valve? there is a bypass valve at...
4helpful
Where is the bypass valve on the water heater?Just bought the trailer and unable to fill water heater?? Any help
2answers
RV water heater problem: my water heater ignities, when I turn on the hot water faucet there is a steady flow of water but no hot water. The bypass valve is parallel with the cold water line. I can only...
The first question is this
From the outside of your RV is the water heater square or is it longer than it is tall?
If it is square it is a Suburban
If it is longer than it is tall then it is an Atwood
Forest River mostly uses Suburban
How long do you let the unit burn/run before you try the hot water? From a cold start it will take - depending on the outdoor temp. & the gallon size of your water heater, 15 to 30 minutes for the water to get hot.
If you have waited this long then I would suspect the bypass valve is in the wrong position
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
