Thee is a standard wiring connection for stylus cartridges. Looking at the rear of the cartridge, there are four connections. With the stylus point down, starting at the top left and moving clockwise:-
White wire - Left channel out (10 o'clock)
Red wire - Right channel out (2 o'clock)
Green wire - Right channel ground (4 o'clock)
Blue wire- Left channel ground (8 o'clock)
Alternately the connection arrangement could be in a vertical line with alternate pins staggered. In this arrangement looking from top to bottom it will be :-
White wire - Left channel out ( Top left)
Red wire - Right channel out (Second right)
Blue wire- Left channel ground (Third left)
Green wire - Right channel ground (Fourth right)
I hope this helps
SOURCE: My husband unplugged the power
plugs should only go back together one way- if you mean he removed wires from plug- get a manual from Autozone- Hayes manual
