Question about Thomson Televison & Video
Thomson one application error - Thomson Televison & Video
Remote code for thomson pvr JL 8006
The applicable code would be in a compatible remote.
May 18, 2017 | Thomson Televison & Video
My comp.says network error,thomson tg585v8,i cant access my comp.
Check your network settings
Start, control panel, networking and sharing center. Click on your connection, properties. Click on TCP/IPv4 and TCP/IPv6 and click on properties. Make sure the settings say to obtain IP address automatically and also for DNS, then reboot the modem and computer.
You did not specify if you are using a router.
Jan 29, 2013 | RCA Thomson Digital Cable Modem (DCM305R)
I can't open my thomson gateway
What's the error message?Have you tried to go to the exact modem page?
1. open internet explorer2. type the numbers 192.168.1.254 on the address bar then press enter3. you will be routed to thomson page settings if you received any message stating error like can not display page then you need to check if the cables are properly connected.4. if still can not connect, go to the start menu icon5. select the run icon or search bar6. type cmd then press enter7. you should received a black screen8. from the black screen type ipconfig then press enter9. you should received the info like IP ADDRESS, SUBNET MASK and DEFAULT GATEWAY.10. copy the default gateway and type it in the address bar of your internet explorer then press enter11. if you have not received these information (ip address, subnet mask and default gateway) on the black screen after typing the ipconfig then check the error "media state disconnected" which means that your pc and your thompson is not communicating, here you need to try different network cable to isolate issues for the problem might be the cable, network cable port at the back of your pc or the network cable port at the back of the thomson.
kindly rate rate this post, thanks
Dec 31, 2011 | Computers & Internet
Thomson 28WH403S no picture red light flashes
this is an error code and the flashing points the engineer to the fault area
May 22, 2011 | Thomson Televison & Video
Disable SIP AL
connect to the modem through telnet and type
application unbind SIP 5060 saveall
Aug 28, 2009 | Computers & Internet
Mp3 player not working at all is there a warranty at all
Excerpt from the Owner's Manual:
Limitation of Warranty:
THE WARRANTY STATED ABOVE IS THE ONLY
WARRANTY APPLICABLE TO THIS PRODUCT. ALL
OTHER WARRANTIES, EXPRESS OR IMPLIED
(INCLUDING ALL IMPLIED WARRANTIES OF
MERCHANTABILITY OR FITNESS FOR A
PARTICULAR PURPOSE) ARE HEREBY
DISCLAIMED. NO VERBAL OR WRITTEN
INFORMATION GIVEN BY THOMSON INC., ITS
AGENTS OR EMPLOYEES SHALL CREATE A
GUARANTY OR IN ANY WAY INCREASE THE
SCOPE OF THIS WARRANTY.
REPAIR OR REPLACEMENT AS PROVIDED UNDER
THIS WARRANTY IS THE EXCLUSIVE REMEDY OF
THE CONSUMER. THOMSON INC. SHALL NOT BE
LIABLE FOR INCIDENTAL OR CONSEQUENTIAL
DAMAGES RESULTING FROM THE USE OF THIS
PRODUCT OR ARISING OUT OF ANY BREACH OF
ANY EXPRESS OR IMPLIED WARRANTY ON THIS
PRODUCT. THIS DISCLAIMER OF WARRANTIES
AND LIMITED WARRANTY ARE GOVERNED BY
THE LAWS OF THE STATE OF INDIANA. EXCEPT
TO THE EXTENT PROHIBITED BY APPLICABLE
LAW, ANY IMPLIED WARRANTY OF
PARTICULAR PURPOSE ON THIS PRODUCT IS
LIMITED TO THE APPLICABLE WARRANTY PERIOD
SET FORTH ABOVE.
How state law relates to this warranty:
Some states do not allow the exclusion nor
limitation of incidental or consequential
damages, or limitations on how long an implied
warranty lasts, so the above limitations or
exclusions may not apply to you.
This warranty gives you specific legal rights, and
you also may have other rights that vary from
state to state.
If you purchased your product outside the USA:
This warranty does not apply. Contact your
dealer for warranty information.
Limited warranty
For Canada
Thomson multimedia Ltd. warrants to the purchaser
or gift recipient that if any manufacturing defect
becomes apparent in this product within 1 year
from the original date of purchase, it will be
replaced free of charge, including return
transportation.
This warranty does not include damage to the
product resulting from accidents, misuse or leaking
batteries.
Nov 28, 2008 | RCA M4204 MP3 Player
Thomson Lyra Jukebox pdp2860 av system files problem
go to this page, http://rcaaudiovideo.com/en-US/RD2780_Upgrade and follow the instructions, i had this same problem, and i fixed mine
Jul 23, 2007 | Thomson Lyra PDP2860 Digital Media Player
Thomson Lyra pdp2842 Usb Problem
lyradj@thomson.net contact the vendor with this e-mail address. They can advise further.
Dec 27, 2006 | Thomson Lyra PDP2842U MP3 Player
Televison & Video Logo
Top Thomson Televison & Video Experts
Todd Hill
Todd Hill
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
