When connecting to pc it blinks for few seconds then goes off, but can add music. it only says power source plugged in 0%
SOURCE: Sony Nwa3000 appears dead??
First things first-have you pressed the reset button on the bottom of the unit? Secondly- try updating the firmware on your unit the manual way - Go to this link. http://www.sony.co.uk/view/ShowArticle.action?section=en_GB_Products&articlesection=1&article=1154694485490&productcategory=%2FAudio%2FNetwork+Walkman&productmodel=%2FAudio%2FNetwork+Walkman%2FNW-A3000&productsku=NWA3000B.CEK&site=odw_en_GB Go to download the latest version of Sonicstage but dont actually do it. At some point there is a link to update your firmware to version 3.0. Try doing this again, going through the update procedure it suggests, even if you already have 3.0 installed. This might work. Worth a try at least!
SOURCE: Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
SOURCE: pc wont recognize my walkman
Right click on "MY computer" Hit properties. Click on the hardware tab. Click on Device manager. Search for the MTP device. It will have an yellow exclamation point on it. ( this means that there is something wrong with the driver.) Double click on the MTP device. A window will pop up which will prompt you to reinstall the driver. Reinstall the driver, It will take like 2 minutes or so. And then you will notice that the computer now recognizes it!!!!!!
I hope this helps y'all..
SOURCE: I've been using my Sony Walkman NWZ-S615F.it seems
reinstall firmware goto to sony site and get firmware for it
