Would like to see a picture of the correct threading on a Brother LX-3125
Hi Lori.
at this link you will see some diagrams that might help you out.
diagram of threading brother LX 3125 sewing machine Google Search
you could also try this one.
SOURCE: Sewing Machine Motors Runs But Needle Does Not Move
Probably the belt tension needs adjusting, it is slipping like a car fanbelt and needs the same relative "give" when correctly tightened.
Remove the side cover where the handwheel is and loosen the motor fixing to adjust and increase the tension on the belt ....needs some slack, if you can move the belt 10mm with light pressure then it will be fine NOT TOO TIGHT or you will overload the motor. NOTE: If the side panel is not easily removed, ie 2 piece casing split in the middle, take it to a service centre or risk breaking the casing trying to get in....if it is more than a few years since last service, let someone do it all and get a sweet machine back, with no risk for not a whole lot of time or money
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
SOURCE: How to thread a Brother cs-100 sewing machine
Please follow the link below, for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
SOURCE: My needle does not stay threaded on my Brother Lx
keep a thread tail of 3-5 inches & when you sew make sure the thread is pulled behind the needle each time you sew, even if you have to hold the thread tail with your fingers
SOURCE: My Handwheel on Brother LX
sounds like you have the bobbin clutch disengaged. Check to make sure you have flipped it back to sewing mode.
