If your Haier 10.5 model 10TG31SW refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can check:
Please note that it's also possible that there could be other issues causing your refrigerator not to cool, so it may be best to seek the help of a professional if the above steps do not resolve the problem.
SOURCE: my refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem.
2...Check your thermostat and make sure it is on the colder setting.
I hope this helped you,
Please rate me...Thanks
SOURCE: Haier Model HRT02WNC compact refrigerator not cool...
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
SOURCE: need cooling fans for haier
http://www.repairclinic.com/PartDetail/Fan/1222948?modelNumber=HVW18ABB
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
